Thank you.
I really dig your Electras…
Nice system & amazing work on the speakers! That IKEA table is made of hollow material. It would resonate like anything, and hurt the tubes… and sound quality. I would only use it for a TV.
I will forward your message to Bent … Thanks bro
Interesting! I have the Usher Dancer Mini Twos and love them. They might well be lifetime speakers (I’m 65). Please share your findings after the upgrade settles in…
I was shocked when I examined it. Use these parts to build a speaker like this.
We have a proverb “to cross the sea and drown in the creek”.
Especially the internal wiring is incredibly poor quality. I used Jena labs. With the exchanges, the speaker outperformed the classroom.
My favorite side of Magico is the best quality of everything.
In summary I highly recommend the usher modification.
Did you compare these OP Amp for the Emitter with the Sparkos Labs ss3601? I have those in my Emitter II and they are working very well.
I did not have a chance to compare.
I was using Newclassd in the previous amp, so I continued as I was satisfied.
I covered the base of the main unit in ebony. I am very pleased. I also use a shunmook diamond under the main unit. The most effective tweak I have used.
Power cable change for Emitter II is also very effective. I use Furutech FP-S55N power cable and Furutech FI-50 NCF connector.
And change all Fuses in the power supplys and the accu.
Thank you. Which is the appropriate fuses? Their fuses are like non-standard.
Which construction year is your emitter?
The Emitter II is from august 2010
ASR Emitter II Exclusive battery ready
Version Blue with black heatsinks
WBT Nextgen package in silver: 4 pole plug WBT 205ag
and 4 RCA WBT 210ag for CD 1 and Direct
additional 2 RCA WBT 210ag for Sub-Out
additional 2 RCA WBT 210ag for Phono
