Now we’re “notorious”? :((
@admin
I think the main reason for people complaining is that they want to make your product even better and to perform its best. If it was really that bad we wouldn’t stick around this community and being a PITA to you and your team :)). You have a fanstastic sounding product and one of the best communities out there supporting it!
Just for the record: I’ve never heard any pops or alien noises using any PWD/Bridge firmware version or any filters. I use the Bridge only, never tried any other inputs.
Bridge Version:0.2.14i
DAC Version Mark II:2.4.4
DAC Unit ID:009748
CPLD:1.16
USB:1.03
Flash:AT49BV320
LCD:Epson
I didn’t hear any pops either until I turned the PWD volume way down (e.g., 30) and the pre-amp up to compensate.
My experience as well.
Same here, but I have had the AM-tuning sound during alter of sample rate.
I have a Preamp in the loop.
Hi,
Back to FW 2.4.3 and the clicks in speakers came back too. Actually more often than with the FW2.2.0.
The problem occurs mainly in NativeX mode, less in Native mode and never in other modes.
The click (only one if we forget the PWD’s relay click) is always produced at the beginning of a new track having a different sample rate than the previous. Stream change in 16bit or 24bits does not matter.
The click is not dependent of the PWD internal volume.
Moving fast from a track to another let you think that the problem disappeared, but wait few seconds between each track change and the click come back.
I only use USB input with a Intel NUC PC and Daphile OS (LMS and SqueezePlay or SqueezeLite).
I do not use a preamp. Connected with RCA cables direct to power Amp.
!!!UPDATE!!!
I tested with a Preamp in the path with PWD internal volume at 100%. The click in speakers disappeared almost completely. Still a small discharge but acceptable as it does not seems dangerous.
Unit ID: 064543
PWD-D0-3J064543
CPLD: 1.09 (what is this?)
Bootloader: 1.12
USB: 01.03
FW: 2.4.3
No bridge
DAC Version Mark II:???
So nothing new, all is already said in previous posts.
I’d like to know the “DAC Version MarkII”, but I don’t know how to get this information (not on the startup information screen).
And what does “DAC Version Mark II” mean? Is there some possible hardware differences between a PWD MarkII and another PWD MarkII bought to your dealer???
Annoying problem…
Regards,
Pat
patr said: And what does "DAC Version Mark II" mean?
Exactly what it says: "DAC Version Mark II", because there was "Mark I", and I hope there will be Mark III (with DSD/DXD support, please :P ) It's an internal upgradable module/plate.
patr, the Mark II version replaced the digital input board, adding NativeX among other improvements. PSA sold upgrade kits that Mark I owners could install.
@alekz: in your previous post you wrote you own a Markii: 2.4.4 and CPLD:1.16. As these versions are ahead of mine (I just bought my new PWD MarkII) I was surprised. Is 2.4.4 a beta firmware? The last published is 2.4.3 for me.
@stevem2: Thanks!
I believe 2.4.4 is still beta.
Yes, 2.4.4 is beta, but I’m not sure what the differences are (if any). At least I did not notice any changes, but as I said I never heard any alien voices coming out of PWD
I’ve the blues :((
NativeX is a way better than Other modes for me. Unfortunately, I’m stuck on Native mode to avoid these ticks in speakers each time the sample rate change.
Someone reported he tested another PWD on the same system having not this problem. I’m thinking to ask my dealer an exchange…
An exchange may not help. Many of us thought we did not have pops only to discover they were there but at a very low level (only became apparent when volume on PWD was dramatically reduced and volume of preamp increased accordingly). How apparent the problem is appears to be highly system dependent but the ticks and pops are more common than we first believed. You might see if your dealer will loan you his demo unit to see if that makes a difference.
@stevem2 And what is the plan to fix the problem? Can we expect from PSAudio a solution soon? Are you confident that a solution can be found?
Or do I have to consider that I bought a DAC that does not fit my system and have to put my brand new PWD on the used market (with loss for me)?
Update: To be sure it is not my USB source, I’ve tested the optical input and got noise on ActiveX mode too.
You shouldn’t have ticks when the sample rate changes if you’re using the latest software we offer. Can you confirm what firmware you’re using? Perhaps if you contact us directly we can help. There’s no need to put this fine piece of gear on the market. PWD’s work great if you use the appropriate firmware. Feel free to contact us directly for help.
Hi, all my information is above in this thread (posted on February 12). The latest FW 2.4.3 is installed since the beginning even if I tried the 2.2.0 which was less prone to this problem. I reverted back to 2.4.3 anyway.
Who is the direct contact? I’ll contact my dealer in first on next Monday.
@patr Contact me or Alex directly via email paul@ psaudio . com
Paul, I don’t see anything in the beta thread or this one that indicates the issue has been resolved. Did I miss something? I’m one of the ones who uses a preamp and does not notice the pops unless I turn the PWD way down and the preamp way up.
Paul, it is known that there are still owners of a PWD Mk II with the official firmware 243 that suffer from ticks and pops when changing the samplerate. This thread started after the launch of 243 when people reported the issue. You’re reaction suggests that you didn’t know. I was assuming that PS Audio is still working on a solution, because the ticks and pops issue for a lot of owners is still not resolved. Greetings, Wybe
