Turn it off in the back-unplug it and wait a minute or more - plug it back in and turn it on and see what happens.
When i went to 306 the update showed availableā¦several times the update just stuck at updatingā¦after several tries it finally worked. So yes you need to put 306 onā¦aftwrward I put 300 back.
All good no pops
All good hereā¦no pops clicks or farts
Noā¦the bridge showed the update after i installed 306ā¦but would stallā¦after 4 tries it just went throughā¦nver saw any device settings or update anything with mconnect
DOHā¦dang youā¦why would the free version have device settings but not the paid version? Weird
Thanx for setting me right
10-4 (superfluous words and stuff)
By the way, I decreased the minimum post length to four characters (and did the same for PMs, even though no one has mentioned this as an issue).
I expect 10-4 would have been enough now.
Enjoy!
Great!
Now I get to overuse ā10-4ā.
A good tweak I think.
Thanks.
Go for it!
10-4
Thanks for the idea, I tried it, but itās still randomly jumping to 50 in the middle of a song. Iām awaiting a warranty replacement for my Matrix, so Iām using USB, but it still shouldnāt be doing this. Happens on Roon or Audirvana. Iāll call PSA tomorrow.
Good luck Buddy. I am sure that Paul & Company will take exceptional care of your issues!
Using DSD Senior with latest Snowmass 3.06. Just updated BridgeII to latest 3.6.86 from 3.6.17 via DSD Senior front panel without issue.
Could some verify if they get station art on the DSD Senior when playing radio thru Vtuner in the Mcontrol app. I donāt with either BridgeII version 3.6.17 and 3.6.86 but I did with previous BridgeII versions.
Tidal, Roon, and Qobuz art is fine. Havenāt tried Spotify.
Thanks for testing.
No station art on my Sr via VTuner. OK on Spotify.
Thank you very much for confirming.
my DSD jr jumps to 50 too⦠itās annoyingā¦
What a disasterā¦
I found if I removed my W4S RUR from the usb chain and just used a direct usb link between my MacBook Pro and the DSJ, that it only jumps to 50 in the beginning. From there on out, no jumping to 50.
Iām awaiting the arrive of my Matrix replacement, so canāt test I2S until then.
Worst comes to worse, Iāll borrow a windows laptop and revert back to the previous Bridge version, actually several versions ago.
It is RIDICULOUS that a bridge update would throw off the USB volume functioning. Iāve used the W4S Recovery for 2 years with the DSJ with no volume issue.
Did you personally have an issue?
Also no station art on my DSsr with Vtuner. Had it with previous verisons like you said as well.
