DirectStream DAC MK2 MountainTop - Mount Massive
Hi Paul,
Done all that and still no function.
Sent you a reply earlier to your weekend message, it has all info.
What do you mean “no function”?
What “does not work as advertised” mean?
Paul does not receive private messages If this is how you sent the information to him he will not see it.
Please post the information here. Paul will see it. And it may help others.
Thanks. I did not receive that. Can you email me directly? Paul @ psaudio.com
Hi Paul,
Email just sent to your ps audio email address.
Stephen
Thanks, Elk. And Steven, thanks for sending me an email. Elk’s right, I am too lame to figure out private messages.
DirectStream DAC MK2 was running for 24 hours straight, and the surface is barely warm. But I noticed the bottom at rear is hotter than the top surface. It is better to elevate it higher than the stock feet to help air circulation.
I use three Orea pods with a 1.5x1.5 sorbothane sheet on each (duro70) to elevate it above the surface. I tried metal columns, Sorbo. rings and VooDoo footers in the past, but found SQ is better with the current setup.
What is you positioning of the 3 Orea pads?
Two in front and one in the back middle. I like the look, and I am not sure if I compared the sound (do not remember).
That’s the way the 3 feet are on my HeadAmp GS-X mk2. However, my Innuos ZENith Mk3 has 3 feet in a staggered pattern. Guess there is no “right” way. I agree with the “look”.
I changed streamers from a Lumin U2 Mini/SBooster to a Lumin U2 streamer and the ultrasonic issue with Massive Beta improved, significantly. Previously, Massive Beta was unlistenable. Much thanks to one of the Forum members who said Massive Beta needed “break-in” time. I set the MK2 volume control to 94 and adjusted the desired volume using the Lumin U2 digital control with the LEEDH turned on. Since my setup is digital-only, I don’t use a preamp,
The “Massive
