Will happily test.
BTW, switched to a coax connector and same issues.
Also, whether I switch tracks via Roon or via streamer control I get the double tsk tsk. So, I surmise, not a Roon issue.
Thanks, Dave
Will happily test.
Thanks, Dave
I have a mixed result, mostly positive. I think once going from pcm to DSD I heard a very soft pft, sound. Very soft. it was there, but nothing like before. Most everything else nothing. I will try and note anything else I hear.
Iām not sure Iāll get the soft pft sounds much quieter, but weāll see.
If Iām not having tick pop issues do I need this update which Iām finding impossible to install?
No, you donāt need to worry about it if you donāt want to.
thanks
I did not have any tick pop issue, I had 2.3.3 and 179 and got the update anyway. I now have 2.3.6 and 198. In my system I heard a SQ improvement so I will stay with it.
Of course, I maybe the only one that have heard an improvement so far.
I do have a friend bringing over some USB sticks later, but thinking if it wasnāt a sonic upgrade why bother, but now you say ā¦
Just in case it helps the āstandard problemsā people have updating the FPGA are:
With your new highly resolving i2s cable, you may hear a SQ difference, I hopeš
my computer cannot unzip the update
I presume you have a MAC then? Iām a Windows user and donāt have any MAC experience, but perhaps someone else can chime in here.
yes mac
There are three ways to unzip files on Mac: you can double-click on the zipped file, right-click and click open with Archive Utility or use third-party software. Letās look at these ways closely:
Some file formats, like Roshal Archive (RAR), need software to unzip and turn them into a folder. So, if you want to unzip such files on Mac, youāll need to get good software to help you with this. Parallels does a great job of decompressing different formats like Tar, 7z, and RAR. With such software, you can change the default extraction destination, create a new folder for extract files, and automatically open the folders once the extraction is done. So how do you unzip a file on Mac using software like Parallels?
Thanks. Never had trouble before
I keep getting unsupported format
Perhaps try downloading the zip file again.
Waiting for my kid
Download link:
Just installed 2.3.6 and Antero198 no problems. Instructions are certainly clear enough.
