Thanks adimon putting both art off I can now load twonky now to see if I can get it all working.
Yes all is working now with a reboot of the bridge. Lets see how long I hope for years.
Ok No music for me tonight. (Elyric find easily minim server but My ipad or my iphone do not want to connect to the perfect wave. I have reboot the router. I have try everything I can but it does not work. maybe tomorrow!
I have read that there is a bug if you place the perfect wave with a static address. I also change that with no effect. I really does not understand because I had the feeling that not such a long time ago it did works (before ios7 of course)
@flaude: finally after one hour elyric found the perfect wave! I just do not understand?
found on my ipad first and after on the iphone!) But whatever now it is too late to listen music. Time to go to bed.
I really do not understand
I have been running eLyric on an iPod Touch 4 originally purchased in October, 2010. Recently I updated the iOS to 6.1.5 (10B400), then eLyric quit working. It failed to load when I attempted to run it. I have updated to 2.1.1 and it still fails to start.
Has anyone had a similar experience with the iPod Touch?
My tablet is a Google Nexus 7 only a couple of months old. I tried BubbleUpNP and it works for playing my server. I can set up and save playlists, or send one on the fly. I can control the volume on the DAC, but noting else. It also does not send the track, album title, and art to the screen on the DAC. That all displays on the screen of the tablet. One other thing it does have that eLyric does not, a repeat feature you can turn on or off. I have not yet figured out how to use it for Internet Radio.
The question is, will eLyric ever work on my iPod Touch? I’m not too keen on buying an iPad to run eLyric and since it is the most functional control for the PWD/Bridge combo it would be nice to be able to use it.
I tried most streaming solutions and settled for Jriver media centre teamed with Jremote
The operation is stable no issues to report playing 16/44.1 through to 24/192 as upnp, the only Gap is “gapless” play-back, however this gap will be resolved after the release of PS Audio WaveStream.
I am using the WaveStream software and configured Jriver media centre to stream all files as 24/96 and the play back is faultless and gapless is resolved. Hang in there PS Audio is on the case.
I would recommend Jriver media centre teamed with Jremote for Ipad if you want to listen to your music without the associated software glitches.
Happy listening
Cheers
John
The operation is stable no issues to report playing 16/44.1 through to 24/192 as upnp, the only Gap is "gapless" play-back, however this gap will be resolved after the release of PS Audio WaveStream.
Happy listening
Cheers
John
John,
Thanks for the "working combination" you shared with us.
To get this "construction" working we need the "Wavestream" in the system.
Can we join the "beta tester" club ?
Thanks
@paul - Having control of the PWD settings via the Bridge webpage would mean we could use other UPnP apps and still have control of the PWD using our iPads / tablets.
Not sure how that works but I have spoken with Dennis about it and he said “it’s easy”. I have asked him to do that.
Thanks Paul
@Paul,
if possible, can Dennis add volume control too?
my pwd is not in sight and I always use elyric to cotrol volume too.
Adding volume control does not make sense. You have JRiver, ELyric, … whatever to control the volume. The only features necessary/helpful are the ability to select SRCs and filters. Basically the PS Audio tab in ELyric. Us users of JRiver (foobar or other 3rd party servers) can then eliminate ELyric completely and remotely access SRC and filter options by typing in the PWD’s IP address.
great idea.
Please also consider a verification element since the front panel is difficult to see from a distance.
Something like the ACTIVE selection lights up or has a halo?
This has been implemented already (more or less):
http://www.psaudio.com/forum/#/discussion/comment/63228
The only difference being that it is not part of the PS Audio web page.
Sorry Charlie, but Apple does not allow return to older versions unfortunately. Can you upgrade to IOS7?
Can you provide us the older .ipa file??
I will install by myself....my IPAD it's still on ios 6.1.2 and E-lyrics does not work well!!
I do not want to ugrade to ios 7 righ now.
THX
F.
My elyric is not working on my iPhone 5s nor the iPad since the Apple software upgrades but I’m using Linn Kinsky with the iPad to play my computer files through the bridge and it is working. Even cover art is displayed on the PWD.
Hope we can fix this soon though.
My elyric is not working on my iPhone 5s nor the iPad since the Apple software upgrades but I'm using Linn Kinsky with the iPad to play my computer files through the bridge and it is working. Even cover art is displayed on the PWD.
I know but kinsky doen not transcode to wav.....and the PWD sounds really better with wav.
My Nas Music Lib is all in alac...
F.
@freek
get the Audionet iMM, the volume control works with the PWD!
And the alphabetical order works as well.
@freek
Thank you for this advice! I downloaded this app and have tried it out.
It seems to be the best control app I know of so far!
Very stable, very clear with similar features as eLyric.
Yes But it cannot transcode!!!
