Good for you, Al. Frankly it’s refreshing to get a report like this for something, rather than the continual “just made a load in my pants, it’s so good!” hyperbolic enthusiasm for so many of these relatively minor things.
Al
A bargain at a quarter of the price. You should be skeptical about that.
Either it’s broken or her system is too dominant. A $600 SR Master makes a significant difference.
What is the tower doing? Atmosphere, music with the right smell and audience effect.
I’m currently researching the next tweak. Ground box for HF suppression. Tourmaline, shungite, etc. are used there.
I think similar to the EMI film described by Vmaxx.
Magic Audio’s black powder will also be tourmaline flour and will be used in your fuses. The graphs of SR and QSA will probably also work on this basis.
I had also seen another fuse online for about $30 that was coated the same as the AM masterpiece. Unfortunately I don’t remember. Could have been refine. The tourmaline color is probably also used by the military to keep planes from jamming.
Greetings Andrew
Hey Luca, just being curious to learn if you had a fruitful contact with the dealer?
Btw, I’ve returned the outcoming fuses last Tuesday and received the cashback on my bank account this morning as well as an accompanying email wishing me continued listening joy from my purchase.
Hello, is there anything new about the SR Master? New users or insights ? The slight accents on the S sounds that I mentioned at around 100 hours have gone down. Although I have to admit that I didn’t manage to listen to hundreds of hours of music without one or the other tuning part. Greetings Andrew
Funny thing though, I was running the AM Master 1 in my JC5
power amp and swapped the SR Purple in.
While the AM Master 1 has more body with good highs, the SR Purple
has more bone along with dynamics and better presence…again just my
.0002 fwiw opine…
Wish I could get the best of each one rolled into 1.
It really comes down to how do you prefer your music…
I ordered a M-1 instead, it just doesn’t make sense to order a Master fuse that costs over 40% of the SW-10 switch.
However, my new Lumin U2 can use a good fuse too. But even that I’m not sure I will spend $600 for a fuse (last I check there’s still no discount on Master).
