P10 and amp failure/problem
Thank you for good idea! I will follow your advice.
Steven
As you don’t have a clue about the OP’s electrical service provider, his home or the condition of his electrical system you are again just making things up as you go along. And unless I have missed it somehow in the abundance of posts about your personal system over the years you have no experience with the current Power Plants to make an assumption about what did or didn’t happen with his or his panel. As was the case with other members his initial explanation didn’t make sense to me so I asked questions he answered and I dropped it. It’s now up to the distributor and PSA to make the determination.
I’m afraid you are too hopeful in your expectations that testing of each component will result in clarity from the tester on why the failure occurred. That generally does not happen as people have a tendency to hedge their bets in these situations unless legally obliged.
While EU consumer laws and electrical regulations are robust, these do not extend necessarily to liabilities, contingent or otherwise, to say nothing of consequential loss.
In the UK for instance in relation to defects, the Supreme Court also handed down a famous judgment in Hastings v Finsbury Orthopaedics [2022] (reinforcing the approaches of the High Court in Wilkes v DePuy [2016] EWHC 3096 and Gee v Depuy [2018] EWHC 1208)
“The test of whether a product is defective is whether the safety of the product is not such as persons generally are entitled to expect. The test is not what is expected but one of entitled expectation. The test is an objective one. The standard of safety is measured by what the public at large is entitled to expect.”
The OP needs to revert in the first instance to PSA, and invoke local consumer protection if applicable. It is unlikely pursuing liability will be fruitful outside of legal proceedings.
Steven, you have subjected us to this lecture dozens of times. We got it the first time.
Instead of pontificating and speculating, let’s allow those involved work it out.
@franta2 may then report back to whatever degree he chooses
So it took 43 people to change a light bulb (-:
You just go on and on and on - talking to yourself about yourself…!
Correct this pertained to hip implants but this is case law being used as a general precedent here which is the reason why I followed it with the quote.
You are also behind the times when it comes to hip replacements. In my medical experience I knew of no Orthopoedic surgeons who would advise a patient to be in pain and delay as long as possible, because they only last about 10 years.
IMO, this thread title is presumptuous.
Good luck with troubleshooting and accomplishing your repairs.
[Post Script: Appreciate the consideration RE: original thread title.]
Agree the title of the thread is misleading, and I do believe it has been changed as well. Hmmm.
Yes, a more reasonable title now.
Plus there are at least two more possible causes of the situation that have not been discussed or resolved but they don’t fit Steven’s need to pontificate as a “consumer advocate.”
I changed the thread title in an effort to make it both accurate and fair.
That could be the response of 2023! I’m still giggling.
Perhaps in England.
Very sad.
I don’t believe a powerplant is not protected against everything that could cause harm downstream…simply because this I guess would be the end of powerplant sales (to those who‘d know). My only topic is…why isn’t this clarified here.
Some may wonder why I care at all although I don’t even own one. I wonder that those who own one, don’t.
Huh?
This is not the case in England. It may have been a few decades ago. Not now.
You mean why this should be problematic for powerplant sales?
Would you use one if you knew downstream damages could happen due to a failure in this unit? I don’t believe in successful refund cases for expensive amps then.
But as I said, I guess there is a measure that this can’t happen,
I am certain this is the case . . . I should have made explicit this was sarcasm.
Huh? meaning I was unable to parse your post. Your second post helped clarify.
I recall past discussions where it was stated a PowerPlant is not going to harm a downstream component even if the PowerPlant fails.
I confused upstream/downstream, sorry, it’s corrected now.
Thinking about it, that might not be so easy, to safeguard a unit that is itself responsible for providing the power. It can certainly be programmed, but this control program itself again can be prone to bugs or malfunctions. Then remains an independent safeguard on a different level,of integration (something like an additional fuse). But I think this isn’t favorable sound quality wise. Would really be interesting how it’s solved.
