PST Firmware Update 2.4.4 is Available
totally agree on the wipers…
Unless it’s the one on the back window. But that only works in reverse.
the rear one helps me go straighter in reverse, but not faster…
Unless it’s raining. Then the new wipers will help you go faster. :grin:
I was a fortunate one that didn’t have previous issues, but decided 2.4.4 had been out long enough I’d update anyhow. Took 2 tries using the USB method to load, but all good & working perfectly.
At least, FW2.4.4 also fixes the main power up init to “>” icon. Here is what I saw with FW2.4.2 after the main power on
now it shows “
I always think an oil change makes it faster…
It always seems that way for sure!
I use Valvoline VR1Racing Synthetic motor oil. It give me more horse power and high performance just like AQ Dragon cables makes my system go faster and higher performance.
I stick to wine—it sharpens my senses and dulls my impulses.
Or is it the other way around? :thinking:
You are invited to the room of quotes o the day…
I use cannabis to enhance my senses and slow the flow of time. Have you ever enjoy “The Time Has Come” after a little weed?
I am about to have my third Mango Margarita. Now would be a fine time to ask for a favor.
Kindly send me some Stealth XLRs
I actually will be in a position to do that tomorrow. Matt already has one pair of mine on loan.
V16 Sakras. Nobody loans out V17s except George. And you have to be me for that to happen.
drat
The V16 will slay anything not a V17.
I was hoping that this update would once again allow me to press play when the tray is open causing the tray to close and the disc to play, but it doesn’t. I still get a brief start of the disc and then it stops.
That’s a common comment, and one I myself have had. I decided to get over my old habit and into a new one.
Also, I upgraded like a slacker, and so only recently. I’ve always done WiFi, but kept getting a failed update, so resorted to the thumb drive for the first time. Worked like a charm. Easy peasy.
Put a disk on open tray, on my PST, using play ctrl on the unit, will auto play. But on the remote, since PST remote requires two operations under DIM mod, press play under DIM mod, will not auto play, even after Tray close. Under nonDIM, will auto play.
As the OTA update, I never use it, and always has the PST network feature turn off, since somewhere I read network is noise, and if have OTA on just to wait for a firmware update once a year, say, look like not practical for me. I thought the network feature on PST is carried over from previous player that need network to get the album arts, but PST does not have that feature.
